It will probably fit with modification. The biggest issue is the head gasket issues the 3.8 engine has. If you really must do it, use a late model block. The 3.8 from either 1999 or 2000 and up have a beefier casting and the later heads have thicker decks. If you haven't found it yet, check out
http://www.tccoa.com
