Flexplate for Late motor to early C4
This is fromm the FRPP catalog.
Did you know…
1968-80 302 engines were built with a 28-ounce imbalance factor.
1981-01 302 engines were built with a 50-ounce imbalance factor.
1969-97 351W engines were built with a 28-ounce imbalance factor.
1970-74 351C engines were built with a 28-ounce imbalance factor.
NOTE: Severe engine damage will result if you use the wrong flywheel or damper on your engine.
Based on that, you need a 28oz C4 flexplate. These should be easy to find localy is wrecking yards that have older cars or call a Mustang shop in your area. Get the small reinforcing ring while you're at it. The Ford part number is C2OZ-6A366-A. You can ask your local Ford dealer parts counter for one.
Patrick Brown
62 Falcon - 331 stroker - C4
<font size=-1>[ This Message was edited by: pbrown on 12/30/06 12:37am ]</font>
<font size=-1>[ This Message was edited by: pbrown on 12/30/06 12:40am ]</font>
