Drop base air cleaner??
Not the answer to the question you asked ... but closely related.
The "best" base, opening, transition to your carb would be a funnel. With proper shape, proper lenght - it would not only allow a clear unobstructed path to the carb, it would act as a venturi, might even increase horsepower throughr ram effect.
The further get away from the idealized version, the less benefit you get. A drop base causes the airflow to turn to get into the carb mouth...which is not what you want to do - if you can help it. Also, most people who use them, as mentioned, are trying to fit a larger filter in a limited space; due to hood clearence or other packaging issues.
Bottom line - A raised funnel is better; a flat base is OK - a well designed drop base is a crutch that can allow you to run a decent sized airfilter (3+ inches) even when you have clearence issues.
