347 power estimates
I've always enjoyed the posts listing the engine builds along with comments , suggestions and power estimates. I thought I would throw mine into the hopper to see what everybody thought.
65 mustang convertible
347- Eagle crankshaft-3.400 stroke
4.040 bore
JE pistons
Holley 750 vac. adv.
Bennett custom cam- hydraulic roller-Harland sharp roller rockers-1.6 ratio
lift- .536 intake .544 exhaust
duration@.050-224 intake 230 exhaust
Edelbrock performer heads
heads opened for larger valves-1.60 / 2.02
performance 3 angle seats, backcut valves
performer rpm intake
3/8'' fuel line-Carter high volume fuel pump 8psi
melling high volume oil pump-120gph
MSD distributor
C-4 trans with 2600 stall
3.25 8'' rear with traction lock
The headers and exhaust are from the original 289 and would like to upgrade. Standard tri-ys with 2 1/4" meineke exhaust
along with Dynomax turbo mufflers. It's a little tight underneath because it's a convertible so I'm not sure how big I can go with a mandrel exhaust. I've been looking at JBA tri ys along with Doug's, Accufab and Ford Powertrain however I am certainly open and would appreciate any suggestions. By the way, it's mainly for the street.
