I found this on another forum. Not bad for a smog motor!
http://www.dragtimes.com/Ford-EXP-Timeslip-8574.html
Here's what he said in an email.
"I had thought for years that this would make a good combo but had been talked out of it. I finally built one anyway. The first combo used 4v closed chamber heads with some filling of the intake ports and internal porting of the exhaust(along with plates to fill the bottom of the port). With a tunnel ram, (2)stage3 barry grant 660s, an engle flat tappet cam, flat top pistons and stock rods and crank, it ran a best of 6.05 @ 112mph shifting at 7000 rpm, in the 1/8th at sea level. That ET would equate to an approx. 9.5 sec 1/4 mile et. The flat top pistons with the closed chamber heads gave approx 12.2 to 1 compression.
I ran that combination for about 5 years then decided to pump it up a little.
13.7 to 1 compression
aluminum rods (6.967"[img]/forums/images/smiles/icon_wink.gif[/img]
stroke stock crank 4.125"
.040" overbore
roller cam 286, 296, @ .50 with .750 lift w/110 cl
spayed 4 bolt main caps (showed evidence of cap walk with 2 bolt)
self made hi-port plates for exhaust side of the heads.
same intake and carbs.
The et posted on dragtimes was the first time out with the new motor , 900 feet elevation and we were dialing in a new four-link setup. I feel certain that it would have run 5.70s if I could have made another pass after making adjustments. I was also shortshifting at 7000. The cam mfg recommended a 76-7700 rpm shift point with this combo.
Since then I've gotten myself into an upcoming match race situation with my brother (53 willys w/blown 427 alky) and in preparation, have changed mine over to a dual Ron's Toilet alky injection system. I haven't made a pass with it yet, but if the change in it's sound is any indicator, it's going to be interesting!!
The biggest aggravation in using 400m and 4v head combo is the intake manifold situation. I used modified weiand spacers for a while but finally made my own and had them welded to the manifold.
The extra cubic inches is just what the 4v heads need to make them work and really turns the 400m into a mid-range torque monster when properly built. I'd love to see more people use them so maybe some aftermarket intakes might become available.
I ported the heads myself but have never had them flowed.
I wouldn't overbore more that .040 at this compression without filling the block.
As far as max rpm,,, the crank is the limiting factor. With the lightweight pistons and aluminum rods, I don't plan to spin it beyond 75-7600. Good crank prep is very important especially when using a cast crank."
