On 2007-02-16 07:54, mdula wrote:
.038 multilayer head gaskets
Those are very expensive, and only required with nitrous/blown applications. You could save some money here by using standard gaskets. Plus, the Cometics need a SMOOTH surface to seal properly. I believe the Fel-Pro MLS gaskets have a sticky coating that will work a little better with less smooth surfaces.
If you can see the machining marks on the block/heads where they have been surfaced, think twice about using these gaskets. They can leak water.
Good Luck!
Sorry...they are not multilayer. Its a Mr. Gasket Ultra Seal Jegs part #720-5807 , 45.00 per pair. the .038 will put me at 9.45 compression.
Also Jegs is out of the pushrods...so i didn't order them. i was looking at summit and they are 6.850 in length 5/16 chrome moly and EXPENSIVE 149.00 can I use my stock steel ones??? Im starting to go broke.
'69 Ford Torino Formal Roof 302
Live for this!
[img]/forums/images/smiles/icon_evil.gif[/img]
<font size=-1>[ This Message was edited by: mdula on 2/17/07 4:42am ]</font>
