351M crank converted to 351C crank - is it possible?
Hey, thanks for the replies. It's always great to get some critical and knowledgable feedback before I leap into another project. In answer to some of the questions above I can say.
Crank snouts are the same
Years ago I bought a couple of 400M cranks to build a stroker, but I never did it. So I've now bought a couple of 351M's to turn into 400's. This of course leaves me some spare 351M cranks which would otherwise go to the scrap metal dealer. The 351M/400 was never available in any domestic NZ vehicles so they must be US imports.
The crank counterweights aren't much longer in radius from the crankshaft centreline (1/4" from memory). They seem to add the extra weight through some additional counterweights that aren't present on 351C crankshafts.
I'm going to balance the motor regardless of if I use a 351C crank or a modified 351M crankshaft, so that sort of cancels out alot of the balance bill. It's only the extra work that actually adds to the cost.
A neutral balance flywheel came with a 300I6 engine I got a while back. If I choose to go auto, it's a simple job to remove the counterweight from a flexplate. So I'm only going to need a neutral balancer.
But, I'll be sure to check out prices first. Like you say, a stroker crank may be a cheaper alternative. But living in NZ they are about $600, then I need rods ($500) and special pistons ($600).
Thanks again, any more comments greatly appreciated
Cheers
Tristram
