02-24-2007, 10:39 AM   #1 (permalink)
wcj56
best trans cooler design?
Okay since I can't run a deep sump pan on my new AOD with 3500 stall, I'm looking for the best heat transfer potential in a cooler.
There are three basic designs.
1. The tried and true tube and fin design, normally copper or aluminum tubes with aluminum fins. Flex a lite or Perma cool.
2. Stacked plate design like the B&M super cooler.
3. Extruded aluminum heat sink style usually sized by length 8" up to about 30"
I have been using a tube and fin 7.5"X14" on my C4 and it lasted many years but I really would like to not block my radiator if I don't have to.
In the refrigeration industry it seems everyone thinks the plate and frame is the most efficient using calculations for delta-T. I wanna know what you guys think.
wcj56 is offline   Reply With Quote
02-24-2007, 03:40 PM   #2 (permalink)
Fomoco8
I have had the best luck with stacked plate with a fan Large B&M with fan keeps my high stall rollerized C6 at 180 or lower on a 90 degree day,
Fomoco8 is offline   Reply With Quote
02-24-2007, 10:58 PM   #3 (permalink)
1 Bad 88 GT
A stacked plate and fan combo is the best setup and it allows for installation nearly anywhere and at any angle(vertically, horizontally).
02-25-2007, 04:20 AM   #4 (permalink)
392Bird
The plate is the most efficent, with the only disadvantage being, if you get any trash in the system, it can not be completely cleaned out with a plate. With the plates design, there is not fixed flow path, so trash can get lodged in it, then break free latter. This can be dealt with by installing a filter after the cooler to clean after a mishap. If not, the cooler would need to be replaced,
392Bird is offline   Reply With Quote
