battery volts while charging???
How many volts should i read at the battery while the engine is running?
I had my wires messed up at the regulator, i tried a different regulator i had because i was only getting 12.5 volts while running, and got around 16 volts, i thought that was pretty high, so i tried the same wire setup on my other regulater, and got about 13.5 volts. I thought that was about right.
All readings were taken at the battery
