Coil amp.and volts
14.9 volts is fine..... maybe your meter is reading .5 volts to high... but it is fine.
Points are an on/off switch... they do not use power or current. The condensor/capacitor looks like an open circuit to a DC voltage, so it does not pull any current either.
The Coil is the only item that draws current.
It is difficult to measure the primary current directly, with the engine running. Since the current is pulsed and not a steady current, you must use an oscilloscope to know what the real current is. Using a current meter will only average the actual current reading.
A safer and easier way to figure the primary current is to measure the resistance of the coil. A standard coil will measure about 1.1 to 1.4 ohms Or at 12 Volts applied over 1.2 ohms = volts/ohms = 10 amps
Petronix coils are .5 to .7 ohms 12 volts / .6 ohms = 20 Amps.
Your coil sounds fine. If your loosing power over 5000 rpms, it is probably something else, maybe your carb is not jetted correctly, not enough gas getting to the motor, or your total timing at 3000 RPM's is too far off.
<font size=-1>[ This Message was edited by: Mikes66 on 3/28/07 1:05am ]</font>
