Drop Dist in at 0* or at base timing on pointer.
If you want a trouble free start the first time, Set the pointer (rotor) 1/4 of the way bewteen the #8 and the #1 on the cap. Starting from the #1 Position, and lock it down. That should put you at 22 degrees, enough to get your carb dialed in.
