How should I seal throttle linkage in home-made carb box?
I've seen dyno comparisons of the enclosure setups vs. the bonnet/hat setups, and from what I remember the enclosures perform a lot worse... probably because they don't really direct the air into the carb inlet like the bonnets do. Even if you were getting some boost linkage through the throttle shaft bushings... I think those are a LOT tighter clearance than you'll ever get on a throttle cable passing through, and regardless you're talking about pushing over 600CFM through the carb, how many CFM do you think can leak through the tiny gap on the throttle... maybe 2?
But if you're set on the carb enclosure design, I'd just use an appropriately sized rubber o-ring, and maybe some silicone to seal it up even better if you think necessary.
