Paint preperation question
Jeff. There's nothing wrong with attempting this yourself. I painted all the interior fiberglass pieces in my 69 fastback as well as the dash, console, package tray etc with SEM paint and it looks awesome. Preparation is 90% of it. That $1000 seems very high to me and I'd certainly put it to further goodies in my stang if it were me. SEM products are awesome and can be purchased at your local paint/bodyshop supply store. The majority of the bodyshops here in Winnipeg use it.
With my interior fiberglass panels and sail panel pieces I made sure they were squeaky clean first before sanding. You don't want to push the oils etc into the surface. Once cleaned i scuffed them with scotchbrite pads. Not the coarse ones as my pieces had the 'camera case' grain to it and harsher scotchbrites will flatten the grain. Once they were scuffed I cleaned them with hot soapy water once again. Blow dry with a hose. Then there is a preclean from SEM that is sprayed on and washed off. Then a pre-bond spray that helps the paint bond to the surface. Then on goes the paint which I might add dries very quickly and is very forgiving. My interior was black so it was easy. I bought 'landau' black and it looks great. You don't want it shiny as it wasn't that way from the factory.
I also took all the wiring, instruments from my dash and painted it as well with SEM and it too looks like factory.
You certainly won't use up $1000 in it thats for sure.
Just my .02 worth. [img]/forums/images/smiles/icon_smile.gif[/img]
John
