05-15-2007, 08:30 AM   #1 (permalink)
mountainsurfer
1978 302
Looking at a 78 302 for my Model A project. Anything different or not so good about this year engine?
mountainsurfer is offline   Reply With Quote
05-15-2007, 09:06 AM   #2 (permalink)
blown68
1978 302
Stock, it's about as anemic as they get. But if you are tearing it down for a re-build, I see nothing wrong with it, especially if you are going with aftermarket heads and some other goodies.
blown68 is offline   Reply With Quote
05-15-2007, 09:40 PM   #3 (permalink)
slik
1978 302
Can be good if built right. It's all about the combination... Is it standard or been punched out already. I pretty much have the same block (1980), but was very speciffic about how I wanted to drive the car which dictated what cam and other components to add.
What do you plan on using this in. Is that a Torino on your page.
slik is offline   Reply With Quote
05-16-2007, 05:28 AM   #4 (permalink)
mountainsurfer
1978 302
Yep, It's a 68 Torino GT. The pic didn't come out to well. The 302 is going to go in my Model A Tudor that I'm restoring.
05-16-2007, 12:16 PM   #5 (permalink)
slik
1978 302
In it's stock form should be more than enough motor to move that old coach along. The cars don't weigh too much.
05-17-2007, 09:44 PM   #6 (permalink)
ponyexpress
1978 302
For performance, the 74-78 302 had a taller deck for less compression(pollution crap) than the earlier or later blocks. You can make it run great since I am running a '74 block also. If you are going to do some wheel stands, I would get a different block. It would be easier. A Model A "wheel stander" Hmmmmmmmmmmmm
ponyexpress is offline   Reply With Quote
05-17-2007, 10:25 PM   #7 (permalink)
frdnut
1978 302
Actually the taller deck stopped in 1976..The 77-78 motors went back to the 8.206 deck hieght and got flat top pistons that were pretty much zero decked..To kill the compression for smog purposes they went to a gigantic combustion chamber in the heads...The nice thing is you can chuck the heads and bolt on some earlier stuff and get a very nice boost in compression..Early 289 heads put them at about 10.5 while later later 69-74 351 heads put them at about 10:1 with bigger valves to boot...My brother has one of these combinations.Great low buck engine.
