Need help picking a (new) camshaft
Folks,
I need help picking out a better cam. Last time I ignored every piece of sage advice and went with something far too big and wound up with a street machine that's just a pain to drive... it wont idle below 900 and has way too much rumpity-rump. So I'm looking for suggestions. Goal is a good sleeper street machine with lotsa go when I hit the gas. Remember, this machine will likely never see the strip!! Here's the current specs:
Engine is a 351w stroked to 393.
95 351w block + scat 3.85 stroker crank
kb364s (22cc dish); for a 9.7:1 compression
Current cam:
comp cams xe 282hr hyd roller (.565/.564 lift, duration = 232/240).
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,600-6,500
Intake Duration at 050 inch Lift: 232
Exhaust Duration at 050 inch Lift: 240
Duration at 050 inch Lift: 232 int./240 exh.
Advertised Intake Duration: 282
Advertised Exhaust Duration: 290
Advertised Duration: 282 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.565 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.574 in.
Valve Lift with Factory Rocker Arm Ratio: 0.565 int./0.574 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Grind Number: FW XE282HR-12
Hydraulic Roller lifters
Scorpion roller rockers
Weiand stealth intake
AFR 185s w/uprated springs; 2.02 Intake, 1.6 exhaust PN 1388 w/58cc combustion chamber
heddman 1-5/8 swap hedders.
G-force synchro T5 kit w/steel retainer.
Holley 650 CFM double pumper. (But I'm thinking of reverting to an autolite 4100 off an old 390.)
Everything in the short block has been balanced and assembled by one of the best machine shops in town.
Any ideas or advice?
