05-29-2007, 08:25 AM   #1 (permalink)
joesgt281
67 Tach Hookup with MSD Tach Adapter
Usual deal...stock wiring is a mess.
I believe I hook the red wire from the tach adapter to the red wire on the tach.
Where does the black wire on the tach connect?
For some reason i think it does not go to ground.
Any experts?
joesgt281 is offline   Reply With Quote
05-29-2007, 05:42 PM   #2 (permalink)
alanmacdougall
I think MSD has the hook up instructions at their web-site
alanmacdougall is offline   Reply With Quote
05-29-2007, 06:12 PM   #3 (permalink)
66GT289
Yeah, it's located at.....
http://www.msdignition.com/pdf/8920_frm22049.pdf
If you're trying to hook up an original Ford factory tach,
you'd be talking about a "current" triggered tach and you'd
follow the second diagram on the above link.
I've got an MSD tach adapter on both my '66 and '68.
66GT289 is offline   Reply With Quote
05-29-2007, 09:24 PM   #4 (permalink)
joesgt281
Thanks guys, I have the linked diagram for the tach adapter, as well as for the 6AL.
What i don't get from the instructions for the current triggered configuration of the tach adapter is what wire on the tach to connect to the Ignition Key On wire. Would that be the red one or the black one?
And then I guess the other would go to the red wire on the tach adapter, but I don't know which one.
The other part of the question about the Ignition Key On source of power, is where to take it from. Certain diagrams I have refer to it coming off down the line past a pink resistor wire. The 6AL box instructions suggest not using any type of ballast resistor in the Ignition Key On line to it. So, should I bypass that resistor wire going to the factory tach?
Joe
06-01-2007, 08:00 PM   #5 (permalink)
66GT289
Joe
I'm thinking red wire from tach to hot side of ignition key,
other side of tach goes to red wire off the tach adapter.
I don't know that it matters. It doesn't on a Faria tach and
that's basically the same circuitry as a Ford factory tach.
(Faria/Rotunda/Rally Pac have no designated polarity)
The pink wire becomes redundant and unnecessary in that
loop to the tach. The signal that runs your tach is no longer
being generated the original way, it's coming off the tach
connection on the MSD box. Just bypass or ignore the pink wire by running a wire from the hot side of the key to the
tach. (You could run it from the battery if you wanted, but
the tach would never really be unpowered if you did that)
