breaking up///misfire
Iam having a problem with my motor.It is breaking up(popping through the exhaust) around 5,000 rpm in second gear .if I try punching it in 3rd gear breaks up about 4,000rpm.I switched coils still doing the same.a breakup or misfire what would cause it.the car ran great two weeks ago at the track.The only thing I did since then was get fuel from a local guy out of a drum (Sunoco 110) could it be bad gas,or an electrical or vacuum problem.
It has been awhile since I changed my cap and rotor.I will be getting a new one this week.
John
1966 Mustang coupe,331 12:1, solid cam,windsor jr,vic jr, pro-systems 750dp.flowing 780cfm ,c4 rev man,4,000 9 1/2,4:86 rear with spool.
Best time so far 11.17@120.83 on 255/60/15 M/T drag radials
