07-09-2007, 10:09 PM   #1 (permalink)
1969SCode
axle code de-coding
I'm fairly familiar with Fords door tag coding but am unclear on one thing. The axle code only indicates ratio, not the axle itself, correct? I would think they would somehow specify 8 or 9" in cars like the Mustang, Fairlane and Torino.
1969SCode is offline   Reply With Quote
07-09-2007, 10:51 PM   #2 (permalink)
Re: axle code de-coding
Yes, the ratio is there, and I believe the axle size too... Or maybe it's just some other designation numbers... There are more than just the ratio though...
07-10-2007, 02:32 AM   #3 (permalink)
dacofa
The door tag tells you posi or not, ratio. Number=ratio and none posi, letter=is posi and ratio. Rare is a posi 8". Then you go to the diff tag for more indepth info. Build date, ratio, bearing size, posi, ring gear size.
be happy, eat your honey.
67 Galaxie Axle 9 code Chiefe9 Galaxie Pages 0 09-08-2004 09:47 PM
lincoln versailles rear axle code Roguen All Ford Techboard 2 07-25-2004 09:47 AM
Help De-coding CanadianAndy All Ford Techboard 5 03-28-2004 06:37 PM
Axle code for 93 Ranger 89Trooper All Ford Techboard 2 10-17-2003 06:44 PM
decoding an axle code loman All Ford Techboard 0 03-09-2003 09:07 AM
