Originally Posted by blown33
i had a blown fe in a 67 for years i found that it doesnt mater what cid you have 390 is just fine let the blower make the power and dont spin it over 6500 max they dont like that just use good rods and pistons the tune up is eveything also a big cam doent make much differance but use a good thick block iv split a coupe in the cylinder early blocks and service blocks seem to be thickest it will make tons of tourqe
Was your FE centrifugally blown? If so, I'd love to hear more about your combination. I've considered a 6-71 or 8-71 roots blower, but I don't want that tall of a setup and I don't want that much low end power. I am having trouble hooking up on drag radials with my current naturally aspirated motor.
I have a block with a mix of features. It is a 428 block with the "C" on the back and with the extra main webbing. It also has the larger distributor hole like a truck block. It is not a service block. At least it doesn't have the ribs on the outside. I can't remember if it has a casting date on it now. It has a half-fill of Hard Blok and is at a bore of 4.155". I haven't had it sonic tested. I am guessing that, due to the Hard Blok, I can only sonic test on the top part of the cylinders now. I have a set of Pro-Gram cross bolt main caps I was going to use on the next build. I think that along with a forged crank and aftermarket rods ought to make for a fairly stout bottom end. Max rpm should be in the 6500-6700 rpm range.
Thanks for the reply,
FE Paulie
