Re: 4R70W help
Well the short of it could be that when a trans is over-filled the fluid gets churned up and can foam. Then the trans will loose line pressure and things can and will start to slip. To little. bad. To much. Bad.
Im no trans expert but id change out the fluid and refill with fresh since it sounds like it may have gotten 'foamed up'. I woulndnt know however if the fluid is ruined. Its just what id do.
Good luck.
Other thoughts anyone?
Life long project. No it wont ever end....
