08-18-2007, 01:24 AM   #1 (permalink)
boss302isback
sbf flywheels
other than 28 and 50 oz imbalance...whats the difference between a 65 289 157 tooth flywheel...and an 88 5.0 157 tooth flywheel. the reason i ask is fidanza lists a flywheel for the 5.0 in either 50oz or 28 oz with 157 ring gear...but only a 167 ring gear for sbf 28oz imbalance. but if the bolt holes are the same, i can put the 5.0 flywheel with 157 tooth ring gear 28oz imbalance in my car and be fine.
Rather Be Blown
"Remember...Ford does things exactly a certain way....except sometimes!"
Cheap, Fast, and Good...you can only have two :'(
boss302isback is offline   Reply With Quote
08-18-2007, 05:33 AM   #2 (permalink)
n2omike
Re: sbf flywheels
The bolt holes for the pressure plate are not the same. Plus, the newer ones have a dowell pin in the flywheel to properly center and locate the plate.
66 mustang
2.3 flywheels guzziman All Ford Techboard 2 01-27-2007 05:39 PM
ram flywheels hotrodconsolo All Ford Techboard 5 09-09-2006 08:35 PM
351W flywheels Helmantel All Ford Techboard 3 07-27-2005 05:45 PM
flywheels DARKON All Ford Techboard 1 04-22-2004 09:19 AM
flywheels and balance dave65FB All Ford Techboard 1 04-15-2002 12:50 PM
Holley
Holley
