08-29-2007, 05:42 PM   #1 (permalink)
347LX
what timing light do you use on a msd dig. 6
The directions for my msd dig 6 box say not to use a digital or a dial back timing light. So what kind of timing light do you use?
64GALAXIE 347 STROKER [EMAIL="12.65@107mph"]12.65@107mph[/EMAIL][SIGPIC][/SIGPIC]
347LX is offline   Reply With Quote
08-29-2007, 05:49 PM   #2 (permalink)
392Bird
Re: what timing light do you use on a msd dig. 6
I just use a old cheap inductive pickup light I have had since the 70s. Works fine.
393 stroker, Vortech YSi on E85
3,500 rpm converter, 3.55 gears, Detroit Locker
17x9 Cobra Rs, with 255/45/17 front, 275/40/17 BFG DR rear
http://members.tccoa.com/392bird/
392Bird is offline   Reply With Quote
08-29-2007, 05:52 PM   #3 (permalink)
Mikes66
You want to make sure your timing marker on your vibe dampner goes all the way up to 50 degrees BTDC. The standard marks only go to 25 degrees BTDC, and you will not have enough information to tune your motor.
The MSD Timing tape is about $5.00 Use a regular mag pickup timing light, clamped onto #1 wire.
[SIGPIC][/SIGPIC]
08-30-2007, 01:29 PM   #4 (permalink)
bmcd66250
Exactly. The newer lights are sometimes confused by the multiple sparks. I recently got a old Craftsman light off ebay for $15. Looked brand new and still in the original box.
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, Holley 650 DP, long headers), "Z" T5 w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
bmcd66250 is offline   Reply With Quote
how to get the correct distributor timing on a 302 engine with a timing light darkstage13 Truck Forum 0 11-26-2006 03:55 AM
new fangled timing light??? drewbot Late Model EFI Techboard 0 05-14-2006 06:50 AM
Timing Light? cmf60 All Ford Techboard 3 04-07-2005 05:28 PM
dial in timing light oldstangs All Ford Techboard 6 07-16-2004 07:42 PM
timing light 70stang All Ford Techboard 3 04-01-2002 05:50 PM
