Re: building 289/302
Normal measurements are done in grams to be more precise. It's good that the parts are all close - but that's really not very helpful. You need a rod weighing fixture to measure both the big end and the small end. Also, when you take it to a shop their scale may not be calibrated like your scale, so they'll do it all over again anyway.
You measure all components separately - pin, piston, rod ends, bearing, rings. Add an allowance for oil, then take 100% of the rotating weight (big end items) and 50% of the reciprocating weight (small end items) to get the bob weight. The crank is then spun on a $25,000+ machine with the bob weight attached to the crank pins to determine if the counter weights match the bob weight.
As mentioned, if you're using stock replacement parts, you should be OK. If you have any performance parts in there - forged pistons, aftermarket rods, etc - get it balanced.
