09-17-2007, 07:15 PM   #1 (permalink)
badmts
bending push rods
the problem I have is strange-about a month ago I put afr heads and comp cams roller tip rockers on my 347 with a voo-doo cam well it did ok for a while then it started to tick a little so the tech at work that put it in adjusted the rockers and it did ok ,now if you adj the rockers it will be ok for 10 minutes and then it starts bending pushrods-we are using comp cams push rods-the heads are 165cc non emmissions heads -any ideas?
badmts is offline   Reply With Quote
09-17-2007, 07:54 PM   #2 (permalink)
forthman
Re: bending push rods
What wall thickness are the push rods? if they are not .080 i would say the cam and springs will bend the .040 or .060 wall rods.
Make sure roller rockers are centered on teh valve stems.
Maybe after it gets hot guides are sticking?
1966 Stang Coupe Org. 6 cyl. 351w,Sealed Power Hypers, ARP bolts,Total Seal rings,Eagle H-beams rods,Balanced,Hedman long tubes, Pro Comp 2.05/1.60 Heads, Shaft roller Rockers, Victor Jr intake, Holley 750 DP, Ed Nix Custom .600/.600 254/258 @.050 Solid Cam, Crane solid roller lifters,Richmond 4.11, Strange mini spool, Modified C4, 3500 stall, Redneck Transbrake, B&M Hammer shifter, Shelby lowered, Pro Comp 6Al system. Mickey Thompson 275/50 Et Street Drag radials.
09-18-2007, 04:58 AM   #3 (permalink)
Mikes66
Not sure what model number push rods your using, but they should be Hardend Pushrods for the set up your using.
If they are, then you may have a coil bind, or pushrod length issue.
[SIGPIC][/SIGPIC]
hardend push rods? torino501 All Ford Techboard 3 02-04-2006 09:54 PM
push rods number NoLongerHere2 All Ford Techboard 0 12-12-2004 01:14 PM
Push rods for my E7's? TheGmKiller331 All Ford Techboard 9 10-16-2004 11:18 AM
custom push rods needed FAST 393Clevor All Ford Techboard 10 03-24-2003 03:52 PM
bending push rods!!! 66ford All Ford Techboard 12 12-01-2002 08:09 PM
