10-01-2007, 07:42 AM   #1 (permalink)
64galwgn
351w swap
I have a chance to pick up a 351w out of 82 van and I don't know if it really matters what year the motor is.I want to put it into my 64 gal wagon that has a 289 sitting in her right now and like I said I don't know if it will work or not, thanks for any feedback
64galwgn is offline   Reply With Quote
10-01-2007, 07:54 AM   #2 (permalink)
frdnut
Re: 351w swap
No it doesn't really matter what year the block is unless you want to stick it in without having to do anything..The 1982 van motor likely has a rear sump oil pan and I imagine you will need a front sump pan for your galaxie..You would just have to swap the pan.You will also need to drill a hole in the front cover for a dipstick.
10-01-2007, 07:54 AM   #3 (permalink)
gbic1
Re: 351w swap
Should bolt right in. 351 Is 2 inches wider so exhaust wont work. Problem would be oil pan. Van will have rear sump and you need front. 351 pan is different than 289. You will have to get car pan and pickup tube.
] 20 years Ford Dealer Master tech.
10-01-2007, 04:47 PM   #4 (permalink)
64galwgn
Re: 351w swap
Do you think it would be worth the work of removing and rebuilding? by the way it's not costing me much $$$$
10-01-2007, 04:58 PM   #5 (permalink)
retyler
Re: 351w swap
Yes indeed. That would help that wagon tremendously.
10-03-2007, 04:20 PM   #6 (permalink)
64galwgn
Re: 351w swap
Thanks to all of you for your feedback
351w swap 69stang69 Mustang Pages (1965-1973) 3 10-28-2006 09:49 AM
351w swap Ragtop64 All Ford Techboard 0 06-29-2004 12:15 PM
351W swap falken All Ford Techboard 4 03-22-2004 09:35 AM
351W swap Foxfire Falcon Pages 9 08-17-2003 02:38 PM
T5 Swap on a 351W labzerpa All Ford Techboard 8 07-16-2003 04:45 PM
