11-07-2007, 03:53 PM   #1 (permalink)
Fordguy67
460 Oil pressure issue...
I have a 460 and had little to no oil pressure in a new build. I've pulled the engine and removed the intake. There is a cast 2 inch pedastool with two threaded holes that are not plugged in the center of the lifter valley in between the number 4 and 8 cylinders, these holes in the pedastool are on the same angle as the number 4 and 8 cylinders. Don't know a whole lot about the oil system of the ford engine. When I had the oil pump running on a drill I saw alot of swirling at the back of the engine through the pushrod holes but none up near the front of the engine. My question is might this be the cause of my oil pressure issue? Should the holes be plugged? What the heck are they for?
Thanks,
Scott
Fordguy67 is offline   Reply With Quote
11-07-2007, 04:25 PM   #2 (permalink)
danv
Re: 460 Oil pressure issue...
Without pulling my intake off to have a look, but I'm pretty sure they should be plugged.
Have you tried here? 460ford.com :: Index
2003 Falcon BA XR8 Ute.
1972 Falcon XA GT.
1970 Galaxie 500 Sportsroof.
danv is online now   Reply With Quote
11-07-2007, 05:58 PM   #3 (permalink)
MonsterMach
Yeap ... plug them.
[SIGPIC][/SIGPIC]
11-07-2007, 10:36 PM   #4 (permalink)
paulkane
Originally Posted by Fordguy67 View Post
I have a 460 and had little to no oil pressure in a new build. I've pulled the engine and removed the intake. There is a cast 2 inch pedastool with two threaded holes that are not plugged in the center of the lifter valley in between the number 4 and 8 cylinders, these holes in the pedastool are on the same angle as the number 4 and 8 cylinders. When I had the oil pump running on a drill I saw alot of swirling at the back of the engine through the pushrod holes but none up near the front of the engine.
Might this be the cause of my oil pressure issue? Should the holes be plugged? What the heck are they for?
Thanks,
Scott
Scott,
That is the oil pathway's crossover point and sends oil from the passenger side lifter gallery, accross/through the "pedestal" and over to the driver's side lifter gallery. YES, the two threaded holes in this crossover boss should be plugged with 1/4-inch NPT plugs, available at any hardware store.
Paul
http://www.highflowdynamics.com/
paulkane is offline   Reply With Quote
11-08-2007, 06:28 AM   #5 (permalink)
dacofa
Not should be plugged, have to be plugged. Nut make sure the plugs aren't so long as to stop the oil from going to the driver's side lifters. It's for when they drilled the oiling cross over holes.
be happy, eat your honey.
Oil Pressure Issue on 351W Murff All Ford Techboard 32 08-13-2008 12:20 PM
Fuel pressure issue gresse All Ford Techboard 3 04-14-2007 11:59 AM
351W Oil Pressure Issue - Part Deux Murff All Ford Techboard 7 08-06-2006 07:48 PM
fuel pressure issue... torqueman0 All Ford Techboard 4 12-18-2005 08:30 AM
1979 F150 4x4 400-possible oil pressure issues, carb issue eliteman76 Truck Forum 2 09-19-2005 10:29 AM
