11-19-2007, 01:49 PM   #1 (permalink)
Sponge
Single/Twin Turbo(s) Engine block
Hi,
Just for my knowledge, is a stock block strong enough for a single/twin turbo(s) package? I was wondering if a stock block can handle easily 750hp with a turbo package?
Of course, main stud girdle, less than 15psi of boost, carburated. As engine block, I think about a Summit 5.0 engine block at $500.
Another interrogation would be: how to put a single/twin turbo(s) package on a 67-68 engine compartiment without drilling, cutting everywhere? A Paxton system will fit easily but what about the others?
Dylan
11-19-2007, 02:56 PM   #2 (permalink)
strtcar
Re: Single/Twin Turbo(s) Engine block
Easy answer, sure but for a few seconds maybe
checkout these forums lots of good information TheTurboForums - Index
[SIGPIC][/SIGPIC]
1967 Mustang Coupe
[URL="http://chicago-classic-mustangs.com/"]http://chicago-classic-mustangs.com[/URL]
11-19-2007, 03:31 PM   #3 (permalink)
blown68
You want something that will easily handle 750 horsepower, get this block. I have one with a roots blower running 10 lbs. of boost and it will take plenty more!
http://www.flatlanderracing.com/dartfordblocks.html
blown68 is offline   Reply With Quote
11-19-2007, 11:50 PM   #4 (permalink)
jeremyl
Stock 302/5.0 blocks tend to split down the middle somewhere around 550 horse.
check out toohighpsi.com
85 Ford F-250 6.9 Diesel
86 Daytona Turbo Z C/S
jeremyl is offline   Reply With Quote
11-20-2007, 09:08 AM   #5 (permalink)
Fairlane427
Just a quick note on twin turbos...
Personally, I have NEVER installed a turbo in my life, I build N/A engines only. However, I did study turbochargers quite extensively while getting my BSME. One thing I notice a lot with individuals who have "twin" turbos on V-convigured engines (whether it be V8 or V6) is that they put one turbo on one bank and the other turbo on the other bank. This is a waste and a shame! The BEST way, (and I'm not just throwing out my opinion here, I've gone through some very extensive thermodynamic calculations on this) is to stage them! You have to feed the first turbo with every cylinder, then feed the second turbo with the outlet of the first. To get this set up perfectly, you have to know your desired operating conditions and then there is a LOT of math to be done! Also, there are some trick intercooling/aftercooling things to be done here as well.
Fairlane427 is offline   Reply With Quote
11-20-2007, 11:22 AM   #6 (permalink)
gchero351
Who makes the summit 5.0 block anyways ? they used to be genuine ford blocks and they said to " get them while they last"
dude,do a poppa-willie!
gchero351 is offline   Reply With Quote
twin turbo or not? torqueman0 Late Model EFI Techboard 7 10-16-2004 10:05 PM
Twin Turbo 460 BigBlock460 Late Model EFI Techboard 14 03-05-2003 07:22 PM
Twin Turbo small block BLISTIC All Ford Techboard 18 10-10-2002 10:59 PM
Twin Turbo 68 stang All Ford Techboard 5 02-21-2002 07:42 AM
Twin turbo Fairlane!!! jeremyl The Garage 1 01-22-2002 05:08 AM
