11-24-2007, 09:37 PM   #11 (permalink)
BUSH
Re: Rear Seal Leak
I have gapless rings, Good question on the crank, The block is for 2 piece seal but how do I tell if what the crank has.
65 Mustang convert. Mexican block 302 stroked to 347 with Edelbrock RPM heads, Comp cams #35-518-8 roller cam, victor intake Holley TBI commander 950-21s fuel injection system with forced induction by Novi 2000 supercharger and bottle fed NOS up to 350 ponies.
BUSH is offline   Reply With Quote
11-25-2007, 12:24 AM   #12 (permalink)
1 Bad 88 GT
Re: Rear Seal Leak
Either the crank has a small lip in the rear seal area(2 piece) or it doesn't.
11-25-2007, 03:19 AM   #13 (permalink)
Cobrajack
Re: Rear Seal Leak
I don't think your leak has anything to do with the blower but your crank case pressure readings may prove me wrong!!
All older "Rope Seal" blocks that were changed to "Two Piece" neoprene seals are prone to leak.....believe me I know as it took a year and 5 or 6 engine removals to fix mine!!!
Your best bet is to sleeve the seal journal....that will fix it guaranteed!!! Mine has not leaked a DROP in 4 years or so!!!
BTW, you can hook up your PCV in the normal fashion using a Ford valve that closes when it sees boost pressure in the intake manifold.....I have an EV-111 on my 04 Marauder and have never had any pressure problems...2 years and 71K miles with the blower....156K miles on the car now!!
You can check with Ford parts and get one for T-Bird-SC or Mustangs with SC....maybe even one for a SC Lightning!!??
GOOD LUCK!!! I HATE OIL LEAKS....GRRRRRRRR!!!!
Cobrajack
Cobrajack is offline   Reply With Quote
11-25-2007, 10:46 AM   #14 (permalink)
BUSH
Re: Rear Seal Leak
Anyone have a pic of this lip.
Seal leak 8 in rear end foleysfriend All Ford Techboard 1 09-16-2007 12:55 PM
302 Rear Oil Seal Leak, Please Help BUSH All Ford Techboard 13 06-26-2007 02:06 PM
Shifter Seal Leak? ctimbs C4 Transmissions 10 12-01-2006 07:12 AM
front seal leak 302stang C4 Transmissions 8 06-10-2005 02:08 PM
how to seal exhaust leak Bandido All Ford Techboard 2 05-23-2005 12:53 AM
