11-23-2007, 03:10 PM   #1 (permalink)
MusclePoney
Intake Gasket
I need to replace the intake gasket on my 302 (Edel Air Gap), what is the best way to do it? any tips/tricks?
MusclePoney is offline   Reply With Quote
11-23-2007, 05:59 PM   #2 (permalink)
pbrown
Re: Intake Gasket
I use the brush on gasket sealer on the head and bottom side of the gasket. Toss away the end gaskets and apply a thick bead of RTV in their place. Use a small bead of RTV around the coolant ports. Follow the torque pattern for the intake.
Patrick Brown
62 Falcon - 331 stroker - C4
TFFN no more!
pbrown is offline   Reply With Quote
11-23-2007, 06:17 PM   #3 (permalink)
frdnut
Re: Intake Gasket
Excellent advice by Mr Brown...I'll just add to keep checking the bolt torques as the bolts tend to loosen as the intake settles down..It is not uncommon to have to go through all the bolts several times till they will finally stay at the torque setting.
11-23-2007, 07:26 PM   #4 (permalink)
Blulakr
Re: Intake Gasket
While you have it off, replace the bypass hose and the thermostat. A couple bucks now can save you headaches later.
'69 Coupe, 351C
'05 Super Crew 5.4L
'06 Fusion SEL V6 (momma's car)
Blulakr is offline   Reply With Quote
11-24-2007, 06:58 AM   #5 (permalink)
MusclePoney
Re: Intake Gasket
Good ideas guys, thanks!
Do you think I should use RTV around the intank ports on the heads? or only on the coolent ports?
11-24-2007, 09:45 AM   #6 (permalink)
frdnut
Re: Intake Gasket
No...Only on the coolant ports....Another neat trick is to use a couple of studs to hold the gaskets in place and guide the intake exactly where it needs to go so you don't disturb the gaskets...After you set the intake in place and thread the rest of the bolts in you can remove the studs if you like and replace them with bolts....Some 302s I've worked on have had the 4 studs in the center right from the factory....You can also use gaskacinch to glue the gaskets in place if you don't like the stud idea..EDELBROCK 9300 GASGACINCH GASKET SEALER - SPECIAL PRICE!
11-24-2007, 10:27 AM   #7 (permalink)
MusclePoney
Re: Intake Gasket
ok thanks!
11-25-2007, 12:16 AM   #8 (permalink)
Blulakr
Re: Intake Gasket
Change the oil and filter when you're done, before you fire it up.
'69 Coupe, 351C
'05 Super Crew 5.4L
11-25-2007, 02:37 PM   #9 (permalink)
MusclePoney
Re: Intake Gasket
I just change my oil and filter 35 miles ago..... but thanks anyway
11-25-2007, 02:55 PM   #10 (permalink)
pbrown
Re: Intake Gasket
The concern is that coolant and debris can fall into the lifter valley when you remove the intake. You should lay some rags in the bottom to catch any junk when scraping the old gasket off. Changing the oil will ensure that any coolant that fell through will be removed.
Patrick Brown
TFFN no more!
gasket for air gap intake socal66coupe All Ford Techboard 4 06-02-2005 03:37 PM
What Intake gasket? Thordane65 All Ford Techboard 2 04-26-2005 08:03 PM
Intake gasket... which way is up? rnourse All Ford Techboard 3 06-16-2004 04:15 PM
Intake Gasket SteeLDawN All Ford Techboard 1 07-23-2002 07:00 AM
GT-40P Lower intake gasket hellfirejim All Ford Techboard 0 04-12-2002 11:41 AM
