11-23-2007, 04:04 PM   #1 (permalink)
Thordane65
heater motor / firewall hole
Hey guys,
Ive taken out my heater in the stang... one becasue I never use it (I have no heater hoses and the water pump is capped) and two, because I wanted to clean-up my engine bay all while trying to lighten as much as possible.
My issue is with the hole in the firewall that where the heater motor extended into the engine bay. What have some of you done to cover that? Is there a large grommet for this or do I make a cover?
I'm curious as to what "heater-delete" factory cars had???
Thanks,
11-23-2007, 04:40 PM   #2 (permalink)
deadhorse
Re: heater motor / firewall hole
water pump capped not a good idea-- run short hose from pump to intake -- --helps to cool intake-
66 galaxie 352 -
deadhorse is offline   Reply With Quote
11-23-2007, 04:52 PM   #3 (permalink)
Thordane65
I still have the small one to the intake.
11-23-2007, 06:36 PM   #4 (permalink)
retyler
I would cut a round cover using 22ga, and rivet it in place, with the cover on the inside of the firewall. Use some 3M body caulk strips to seal it. Rivet from the engine bay so they will be flat. Paint it and no one will even notice it.
11-23-2007, 07:16 PM   #5 (permalink)
strtcar
I did the same thing on my 67. I cut a square piece of sheetmetal, and from the inside bolted it in using the existing 4 holes from the heater motor. Painted it black to match the firewall. I then drilled a 1" hole and put a grommet in the middle and use that to route my A/F gauge wires through.
Here are some pictures before I did the grommet
Putfile - Welcome to my homepage!
[SIGPIC][/SIGPIC]
1967 Mustang Coupe
[URL="http://chicago-classic-mustangs.com/"]http://chicago-classic-mustangs.com[/URL]
11-23-2007, 10:32 PM   #6 (permalink)
The factory heater delete car's didn't have the hole stamped in the first place...
Cut some sheet and just the existing holes like stated above
11-24-2007, 04:31 AM   #7 (permalink)
DF66Stang
Here's a picture showing the sheetmetal I used to seal the hole. It was an easy install and was handy for having a spot to bring additional wires through the firewall.
66 Mustang, 289, 10:1 CR, AFR165 heads, Comp Cams Magnum 280 (0.512/0.512 230 duration @ 0.050), BIGS 650DP, 4.62 gears, C4 trans, 3200 stall converter, Edelbrock Nitrous - 100HP. Best run: 11.51 @ 121
DF66Stang is offline   Reply With Quote
11-25-2007, 01:34 AM   #8 (permalink)
jeffstar
I made a square aluminum plate as well.
I mounted an electrical bulkhead connector in the center because I need a fair number of wires to connect various sensors to my home made
data acquisition system.
65 Fastback:393W, G-Force T5, 4.11:1 Moser N-pro case / 31 spline axles, 4 wheel Disc (low 11's)
1966 mustang heater motor foleysfriend Mustang Pages (1965-1973) 2 07-01-2007 05:56 PM
blower motor hole blank off Plate juiceman39 Mustang Pages (1965-1973) 4 06-29-2006 08:25 PM
Heater motor. 85mike All Ford Techboard 5 10-28-2003 12:40 PM
Will the heater core or the wiper motor from a 68 Monterey fit in a 66 Fairlane? deernet All Ford Techboard 3 12-15-2002 08:22 PM
Where to find the hole...in the firewall...for the clutch rod...73 mach 1 OTTO! MightyMach All Ford Techboard 3 11-04-2002 01:49 AM
