11-25-2007, 12:30 PM   #1 (permalink)
hoofkicker
1989 f-250
changing seals in steering box of f-250 4x4.Seals where a mess, looks like some one changed them and put them in wrong. Does anybody know which way the bottom seals go in? If you have any pictures it would be appreciated.
hoofkicker is offline   Reply With Quote
11-25-2007, 07:04 PM   #2 (permalink)
gbic1
Re: 1989 f-250
The big seal goes on top with the lip facing up. The small one goes in second with the lip down then the snap ring. Make sure you clean the snap ring groove. Pack a little grease in the top seal before installing and make sure it is seated and square. Directions usually come with the new seals.
] 20 years Ford Dealer Master tech.
gbic1 is online now   Reply With Quote
11-26-2007, 10:26 PM   #3 (permalink)
Blulakr
Re: 1989 f-250
I've tried to reseal a couple of steering gears and haven't had much success.
Usually the sector shaft has too much play side-to-side and also has a worn surface where the seal rides.
Reman steering gears aren't that expensive.
'69 Coupe, 351C
'05 Super Crew 5.4L
'06 Fusion SEL V6 (momma's car)
Blulakr is offline   Reply With Quote
1989 LX Coupe Roarnracin Mustang Pages (1979-1995) 2 06-28-2007 07:06 AM
1989 EFI 5.0 HO in 1971 LTD brmrides Late Model EFI Techboard 8 06-03-2007 06:07 PM
1989 HO 302 Info Please BRDVPRA All Ford Techboard 6 11-04-2006 07:55 AM
FM just picked up a 1989 F-150 5.0L... admin Truck Forum 13 05-27-2005 09:51 PM
1989 model ? sleepysal All Ford Techboard 5 01-29-2005 01:05 AM
