12-25-2007, 08:40 PM
fasterdamitt
Can a 331 crank hit the oil pump?
Has anyone had this happen. I've had the same knocking noise in three different stroker shortblocks and never thought to check clearance between the 3.25 or 3.40 crank and oil pump housing. I had two machinist listen to it running and they both said it sounds like something is hitting. Another question would be how much clearance between the rod bolts and custom pan is necessary? I know mine is very close. Just asking before I pull the pan.
74 Bronco Frame off resto, Street Fighter 331 stroker, AFR 185\'s, XE266HR, Victor JR, Mass-Flo EFI, AOD, Lentech VB, D44 front, 9\" rear, 411\'s, 35x12.5x15 TRXUS, DC1 15x10\'s, 4.5 DC Broncos coils, 11pack leafs, Bilstein 7100\'s, Bullit Proof Steering, AC.
12-25-2007, 08:50 PM
mavman
Re: Can a 331 crank hit the oil pump?
Some cranks had plenty of clearance, some hit. Seems like the Eagle crank cleared ok (347) but I could be wrong...been too long since I broke it open. I do know that the 331 crank we bought (Scat, clearanced and lightened by crankshaft specialties) cleared, but it was CLOSE. I believe there was about .025" between the pump and the counterweight. I ground a little off the crank before I had it balanced and it balanced out just fine.
As for bolt-to-pan, that's not somethign I've run into before....so hopefully someone more experienced will chime in here.
12-25-2007, 09:16 PM
fasterdamitt
Thanks.
12-26-2007, 11:58 AM
Max
Hello,
my scat 331 crank have minimum 1/4 inch space to the melling high volume pump.
Markus
67 Mustang Fastback
331 stroker EFI, AFR185, FTI custom cam, GT40 upper/lower,
comp pro magnum, 24 lbs, inovate lm1 wb, tweecer RT, tremec TKO, http://www.mustang1967.de
12-26-2007, 02:04 PM
fasterdamitt
Thanks for the pic! My crank is hitting something. I used a stethescope this morning and it sounds pretty bad in that area.
