01-01-2008, 07:12 PM   #1 (permalink)
lgh1157
Disc swap prop valve, "T" fitting questions ?
I have a 64 Galaxie, im in the middle of a 77 Tbird swap.
I got the prop valve off the bird and i wanna set this up right
I have a disc/drum master.
- I'm not sure if the 77 Tbird had a booster - does this matter for the prop valve ?
- If i run a adjustable proportioning valve on the rear line, do i just "T" the front lines off the master ? do i need any sort of valve for the front ? [ i dont think i do, but im not much of a pro when it comes to disc brakes ]
This one :
JEGS Adjustable Proportioning Valve - JEGS
L
...We wanna be free, We wanna be free to ride! We wanna be free to ride our machines without being hassled by The Man!
lgh1157 is offline   Reply With Quote
01-01-2008, 07:19 PM   #2 (permalink)
frdnut
Re: Disc swap prop valve, "T" fitting questions ?
Can you post a pic of what you got off of the t-bird?..It should have a place for the front lines as well as the rear?
01-01-2008, 07:54 PM   #3 (permalink)
lgh1157
The valve has 5 holes, i know how to plumb it. It has the 2 inlets and the 3 outlets, the problem with the valve is that the rear fitting out to the line is huge and im have trouble finding a reducer fitting to run a 3/16th line into it.
01-01-2008, 10:28 PM   #4 (permalink)
KULTULZ
The valve off the BIRD is a COMBINATION VALVE, and is comprised of a front metering valve, center pressure differential valve, the rear proportioning valve and a 5# rear brake (drum) residual pressure valve (this valve may also be in the rear brake (drum) outlet on the MC).
If you decide to not use the later combination valve, you will have to plumb in the valves mentioned individually (available). To test a rear proportioning valve make a panic stop on wet road surface (preferably a skid pad) and see how well the font/rear barke bias is.
[FONT=Century Gothic][/FONT]
1977 LTD II, S-code ["SPORT II" clone project] $1200 MERCURYMUSCLE Vehicles for Sale 1 01-14-2008 04:28 PM
Replacing 8" with 9" questions biglaw22 Galaxie Pages 4 11-03-2007 08:03 AM
Scat 4340 forged 4" stroke 2.75" main FullAuto Parts for Sale 1 10-19-2007 05:51 PM
"Victory by Design" on Speed, Ford Muscle series ga289stocker The Garage 0 07-08-2007 09:35 AM
Did a disc swap.. Prop. valve problems... :rolleyes: wildosvt01 All Ford Techboard 6 08-29-2005 06:55 PM
Lakewood
