Re: mini spool Removal
You should be able to get an open diff for almost free if not free. Swapping your ring gear would be easy. Pinion depth is the hard thing to get right. Changing the diff only requires resetting backlash, which will need to be done even if you convert your diff to either spider gears or power trax.
'67 Mustang coupe, 351w, C4/C5, 8.8 rear
