this might not be a problem for you but i asked why people buy the bolt in ones then weld them in and somebody said the weld in ones were for custom tube frames or something, but the bolt in ones will go right on the stock frame.
Thanks oldschool. I will definitely take your advice.
Originally Posted by Oldskool
If you plan to install Caltracs or Slide-A-Link traction bars, consider installing them before you weld on the sub-frame connectors. Sub-frame connectors are much less likely to interfere with Slide-A-Links, but Caltracs can be a problem if the connectors weren't positioned to clear them at the front eye of the leaf spring. I know from experience that notching welded sub-frame connectors isn't much fun.
I used the Competition Engineering brand bolt on models and welded them on..The CE weld on type are for narrowed frame rails..I was impressed how well they fit..
