OK.... after a little more research the following was found in "The Ultimate American V8 Engine Data Book"
Ultimate American V-8 Engine Data ... - Google Book Search
under the 427 MEDIUM riser "The MR was available from 1965 to 1967.......... Because the valves were larger and spread further apart, they required wider rocker stand shafts, Part Number C5AE 6531 A"
Using the formula in the previous post this would be your part number manufactured in 65 as a first generation part. As your part number was made in 64 and MR stand shafts which were supposedly wider to accomodate larger valves started production in 65, I wouldnt think that you had MR shafts. The High Riser heads were available in 64 according to this book but the preview does not go far enough to give a part number.
Keith/ Bumble
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
