02-06-2008, 02:02 PM   #1 (permalink)
jetnoise
60 Gallon Air Compressor suggestions
I am going to buy an Air Compressor for my home garage-light duty mainly to rum a blast cabinet. The specs seem to satisy my Blast cabinets recommended cfms.
Stopped at Home depot and Lowes, they sell Husky and Cambel Hausefields. Cast Iron Oil type, 240 volt 15amp (not an electrician)They looked identical chinese made I believe. Anyone using these?
I am looking to not break the bank but would like a decent one that's not absurdly loud. and last me a couple of years.
I was gonna buy a KOBALT, but lwes no longer carries them here. Are most of these the same mfr'r?
Thanks for suggestions
70 Mach 1 393W
75 Bricklin 357W
02-06-2008, 02:32 PM   #2 (permalink)
firstandlast
Re: 60 Gallon Air Compressor suggestions
Check out Northern Tool, Harbor Freight and Granger all on line. You can do some comparison shopping and figure out which one you need.
Most home based units are single stage the commercial units are 2 stage have higher cfm rates and can handle continuous use of an air tool without running like crazy.
Always buy the best you can afford so you do not outgrow your tools.
Do not forget to look at the second hand units you may find a deal
firstandlast is offline   Reply With Quote
02-06-2008, 04:56 PM   #3 (permalink)
iwantmore
I have yet to buy a Huskey tool that was not junk. I will not buy any more. The Cambel Hausefields used to be USA. I used one for over 15 years and sold it to buy a used Cambel Hausefield that was bigger. The compressor design looked identical but my new one was only a few years old. The larger tanks are nice! If you plan on keeping it awhile I would also say don't only buy it only on price.
02-06-2008, 05:11 PM   #4 (permalink)
Ranchero65
I bought this one at Lowe's about 4 years ago . Does all I need it to and never have to wait on it and thats even when I use my sand blaster . Think about what you will be using it for and what CFM the tools require. Will you be spray painting a car or truck ? If so make sure it is up to the task. I have seen several people buy what they think is a big enough compressor to later find out it is not . Below is a pic of the one I have .
Take Care
Earl - Ranchero_65 Restomod Slowley in Process !
www.ranchero65.com
Ranchero65 is offline   Reply With Quote
02-06-2008, 06:06 PM   #5 (permalink)
kechke
My 60 gallon 3 cylinder 18CFM at 100PSI came from a company in Canada called Princess Auto. I got it on sale for $650.00. The brand name was Eagle Compressor and it is Made in the US. It has enough oomph to run my bead blaster continuously.
Non Iiligitimus Carborundum
68 convertable
05 convertable
kechke is offline   Reply With Quote
02-06-2008, 06:56 PM   #6 (permalink)
Rcode427
I have used many over the years building houses running air guns . The only one I have that can keep up is from sears . It is 160 psi , the professional black one . The red one is 150 psi and can only run 3 guns max . The black 60 gal tank and added psi will run 4 all the time and is very quiet . I got it on sale for 650 as well .
Kobalt is sold at tractor supply here , never had one so donot know . If you want a shop one find a ol timey 2 cylinder thumper that delivers more cfm with a 250 tank .
02-06-2008, 07:57 PM   #7 (permalink)
aaronford
Don't get the el cheapo at Sears. I got the direct drive and while it does work, it is loud as he11. I do not think it would keep up with a blaster. It barely keeps up with a sander. Does not appear to be well made and has a tiny regulator that prevents any real work from being done. I got what I paid for. Wish I would have saved my money and bought the one I wanted. Likely will, eventually. Might have to give this one away to get rid of it.
Live and Learn,
Aaron
aaronford is offline   Reply With Quote
02-06-2008, 08:14 PM   #8 (permalink)
351bolt
I saw this thread and went shopping as I need a new compressor myself. Found an Ingersoll RAND 3HP 60 GAL for like $500. Read the reviews everyone loved it. Looked at Sears, per the reviews all of them broke within a year.
Pete
64 Fairlane under construction, 420W, C4, ladder bars, etc
92 Mustang LX Coupe 4cyl power
351bolt is offline   Reply With Quote
02-07-2008, 09:55 AM   #9 (permalink)
jetnoise
351 where did you read the reviews at?
Thanks for the suggestion folks!
70 Mach 1 393W
75 Bricklin 357W
02-07-2008, 02:36 PM   #10 (permalink)
347LX
my 80gal IR is the best thing/tool I have ever bought for my garage. do some research on the web and you find alot out about hp ratings and so called "2-stage" unit that are not actually 2-stage. I paid $1000.00 for mine but I looked at many l-cheapo's for $750-$850. Check Tractor supply if you have one in your area.
64GALAXIE 347 STROKER [EMAIL="12.65@107mph"]12.65@107mph[/EMAIL][SIGPIC][/SIGPIC]
347LX is offline   Reply With Quote
Gas is over $2 a gallon bluestreek The Garage 50 06-16-2008 11:05 AM
Jaz 16 Gallon Fuel Cell New sideshow Parts for Sale 0 07-03-2007 06:14 PM
Air Compressor GES The Garage 11 02-07-2007 01:37 PM
Getting more miles to a gallon derekmnoble All Ford Techboard 6 07-24-2005 08:06 AM
Think we are gonna "bomb" Saddam? Gas prices $5.00 a gallon? DynoTom The Garage 123 02-07-2003 09:06 PM
