02-29-2008, 03:57 PM
carnutt331
Calvert split-mono leafs.What height?
I want to order the slit-mono leafs from Calvert.What height do you think I should go with .I dont want the rear too high.Their options are 1" down ,stock or 1"up.
Does anyone have them and what one did you use and do have pics of how your car sits.
1966 Mustang coupe,331 12:1, solid cam,windsor jr,vic jr, pro-systems 750dp.flowing 780cfm ,c4 rev man,4,000 9 1/2,4:86 rear with spool.
Best time so far 11.17@120.83 on 255/60/15 M/T drag radials
02-29-2008, 05:30 PM
dennis111
Re: Calvert split-mono leafs.What height?
I have the stock height Mono-leafs. Here is what it looks like with 26" tall front and rear tires:
This video shows the rear better (once the smoke clears-hehe):
Dennis
11.21@124.0 al naturale
My Racing Videos
02-29-2008, 07:03 PM
carnutt331
Thanks Dennis.I run a 27 tall tire.Going by your pic its going to be either stock or 1"up.
Very nice run.I like the way it leaves.
03-01-2008, 05:23 AM
dennis111
It looks like you have a pretty wicked 331!
If the springs sit too high or too low when you get them, Travis at Calvert said they would swap them out. Only one half of the spring gets swapped for ride height differences.
With the 26" tire, my car "might" be on the high side for a daily driver. I run a 24" tall tire on the street and they let the car sit lower and it has a very nice stance.
In your case, I would be concerned about tire clearance if you went 1" lower.
Dennis
My Racing Videos
03-01-2008, 09:56 AM
carnutt331
Dennis did you notice a difference in your 60ft vs multi leafs?
03-01-2008, 03:39 PM
dennis111
Initially, no not really.
I replaced fairly stiff 5 leaf rear springs which were giving me 1.75-1.80 60's. I continued to use the same stiff Rancho settings and messed with different setting with the Caltracs, but I really didn't see any track improvement. Driving on the street was a big improvement since I no longer had the jaw rattling effect when driving over bumps.
After a conversation with Dave Zimmerman of Team Z, he told me to run the 9 position Ranchos at 2-3 settings and the Caltracs in the upper hole with the 4 speed. From then on my times got better, averaging 1.65 to a best of 1.60 on 26x8.5x15's.
I would suspect that your C4 should give you better times than I have had so far. This year I've gone to a slipper clutch and hope to improve my 60's even more.
Dennis
My Racing Videos
03-01-2008, 07:13 PM
n2omike
Wow, Dennis... You're starting to get serious! I really like seeing your enthusiasm!
I wish you lived closer, as we could meet up for a weekend of racing, sometime.
Good Luck!
Mike
66 Mustang, Toploader 4-speed
Pump Gas 306, 10.157@133.68
03-02-2008, 03:58 AM
dennis111
Good Luck!
Mike
Thanks Mike!
I wish you were closer too. I would love to get some good pointers on where to start with my clutch adjustments. Probably PM you soon to get an idea of a baseline.
Dennis
My Racing Videos
