03-02-2008, 07:37 AM   #1 (permalink)
loman
strut front end drag car
i bought a car that was started by someone else. the struts are mounted but the hood,fenders, grill none of the exterior was ever mounted back on the car. does anyone have pictures or suggestions on how they mounted these on their cars. I'm gonna use a fiberglass hood and bumper, fenders will be steel. also, there is no core support or inner fenderwells and the firewall has been moved back. i've seen the front end mounting kits in some chassis books but they appear to be for 1 piece fiberglass front ends.
65Comet,63Galaxie,71Lincoln
loman is offline   Reply With Quote
03-02-2008, 09:12 AM   #2 (permalink)
badbird
Re: strut front end drag car
I used sq tubing to hold the fenders on a 64 fairlane. The car has modified shock towers. Welded the tubing to the firewall and along the inner fender and then to the rad support. I used 3/4" or 1" sq tubing.
Roger
84 t-bird street/strip 13.22@103mph
65 comet/project
Made in Canada built for speed
http://video.google.com/videoplay?docid=6498304960014012619&hl=en
badbird is offline   Reply With Quote
03-02-2008, 07:28 PM   #3 (permalink)
mavman
Sounds similar to mine, but I am using A-arms instead of struts. But I will snap a few pics and that will give you an idea how everythign mounts. Pretty simple. Basically, there is two small round tube struts running from the cage forward tubes up to the front fenders. Then there is a piece of 1" square aluminum tubing that runs between the fenders that doubles as a place for the hood pins and an upper radiator support. The lower part of the radiator is mounted to the frame (Scirroco radiator) via welded tabs. Very simple and easy to work on.
03-13-2008, 04:03 PM   #4 (permalink)
mavman
03-13-2008, 04:05 PM   #5 (permalink)
mavman
03-13-2008, 04:05 PM   #6 (permalink)
mavman
03-15-2008, 06:41 AM   #7 (permalink)
loman
thanks mavman, the pictures do help. that's kinda the way i was thinking on doing it or similiar.
1965 galaxie front suspension strut rod Blue Fastback Wanted 0 10-22-2007 07:24 PM
66 front strut rods ?? deadhorse Galaxie Pages 25 10-21-2007 03:18 PM
Strut front end Gas40 All Ford Techboard 2 01-11-2006 05:29 PM
Mustang front strut & brake question whlnutEd Late Model EFI Techboard 0 06-02-2003 10:00 PM
front strut rod suspension BlownFairlane All Ford Techboard 2 04-19-2002 05:34 PM
Holley
Holley
