Re: AFR 165 or 185's for a 289?
Joe,
you are a legend in engine builders and I totally respect your opinion but everything else bieng the same compression,cam,intake etc.....you can really say that afr 165's will beat TW heads in overall power? I think it may be close but the TW's should make more.
I helped a friend build a 5.0 for a sunbeam tiger, it was a 5.0 10.2 compression, comp xe274hr cam, a worked rpm manifold and a demon 750 annular VS carb, it took alot of tuning but that sucker pulled 429 hp on the dyno and as I remember about 370 ft lbs, I was shocked at the power, it started around 380 hp and messing with timing,jetting, sec springs brought it up to 429hp to this day I wonder if it was right, I remember the hp# because of a 429 ford. As I remember the low end #'s were not too shabby either. Iknow the heads were milled but not ported.
Hp seemed too high but I sat there and watched it.......
