03-13-2008, 04:41 PM   #1 (permalink)
72BlackOnBlack
Points Eliminator Kit....
Are points eliminator kits worth the money? I'm running a pretty much stock 302 with Accel coil and wires, with an ignition controller in the works, and was thinking that my next upgrade should be an Accel Points Eliminator Kit part no. 2020.
What are the benifits, if any?
72BlackOnBlack is online now   Reply With Quote
03-13-2008, 05:30 PM   #2 (permalink)
MontegoMan351
Re: Points Eliminator Kit....
Personally, I'd go with Ford's Duraspark II. You can even reuse your wires and such if you'd like, or you can upgrade to the bigger cap.
'73 Montego MX 357C Homebuilt EFI, 9.5:1 comp, mild cam, 30lb injectors, A9L computer, Moates.net chip, 70mm TB, 76mm C&L mass air.
MontegoMan351 is offline   Reply With Quote
03-14-2008, 12:23 PM   #3 (permalink)
bmcd66250
I've been running an Accel distributor with a Pertronix module for about five years. I carry points in the tool box just in case the Pertronix craps out. With the Duraspark you could get parts just about anywhere.
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, Holley 650 DP, long headers), "Z" T5 w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
bmcd66250 is offline   Reply With Quote
03-14-2008, 04:54 PM   #4 (permalink)
foleysfriend
How did the combination of the Accel distributor and the Pertronix work for you. Is the Pertronix the ignitor 1 or the ignitor 2. Is it hooked up just to the coil with as the instructions state, or did you find a full 12v supply.
Greg
foleysfriend is online now   Reply With Quote
Accel points eliminator kit foleysfriend All Ford Techboard 0 05-21-2007 08:31 PM
POINTS ELIMINATOR CONVERSION KIT Rubberduck All Ford Techboard 5 11-30-2005 11:00 PM
Comp Eliminator 6 Cyl Mario428 The Garage 2 03-25-2005 08:27 PM
EGR Eliminator??? gorgan1314 Late Model EFI Techboard 3 10-01-2004 04:38 PM
EGR Eliminator??? gorgan1314 All Ford Techboard 2 09-24-2004 01:23 PM
