03-13-2008, 10:01 PM   #1 (permalink)
Juan
Radiator tank oil cooler
Gentlemen. I need to replace a lower radiator tank oil cooler (67 Mustang). I can't find one. I could replace the existing cooler with several elongated copper coils. Any suggestions as to where I could find an original cooler and/or has anyone installed copper coils? Best regards. John--Las Vegas.
Juan is offline   Reply With Quote
03-13-2008, 10:39 PM   #2 (permalink)
Bumblebee
Re: Radiator tank oil cooler
I have to assume that you are looking for a concourse type radiator.... Your best bet may be take it to a radiator shop and have them disassemble the tanks from the core in that case, rig up your own coiled copper setup inside, and have them vat the core and reassemble... you can get aftermarket radiators all over the place or go with Summitt's $89 universal oil/tranny cooler/oil filter relocation kit, Thats what I got for the Gal.
Summit SUM-G4978 - Summit Combination Fluid Coolers - summitracing.com
If it doesn't have to be original I say improve on the original design.
Keith/Bumble
Coming soon to a mid GA Blacktop 65 Galaxie LTD 2D Fastback Rescued Kudzu Queen 99 5.0, 93 GT40 Heads P&P'd, 8.7:1 hyper slugs,E303 Roller Cam, 1.6:1 roller rockers, Edelbrock performer intake, Holley 600, Shortie Headers.
Bumblebee is offline   Reply With Quote
03-13-2008, 10:43 PM   #3 (permalink)
That's good advice
03-14-2008, 06:31 PM   #4 (permalink)
Juan
OK Gents. I am going with the copper coils. Best regards. John--Las Vegas.
03-16-2008, 05:30 AM   #5 (permalink)
PaulS1950
John,
replace the radiator - not the cooler.
The cooler is fit to the tank in such a way that it makes it very difficult to replace. Running a few coils of copper tubing will not replace the cooling capacity of an internal cooler. You are just as likely to ruin the transmission from overheating with your home-made cooler as you are if you just run a small external cooler to replace the cooler in the radiator. Unless you are an engineer and have calculated the heat transfer then leave it to the professional to engineer the coolers. You are dollars ahead by replacing the radiator with a new one that has a new and good factory cooler installed.
Paul
Radiator surge tank 63Sean Galaxie Pages 8 11-06-2006 11:06 AM
Radiator tranny cooler useable for oil cooler? Motorhead All Ford Techboard 9 01-06-2005 03:48 PM
Tranny cooler , Front or back of radiator? brusiertds All Ford Techboard 2 04-22-2004 08:24 AM
How much cooler will I run switching from a three core standard to an aluminum radiator ?? KidPoboy All Ford Techboard 7 04-12-2004 10:59 PM
Gas tank interchange, or custom tank? TheUnfairlane All Ford Techboard 3 03-25-2002 07:45 PM
