03-14-2008, 09:34 PM   #1 (permalink)
mdsporrer
Mallory Ignition E-Spark Conversion Kit
I installed the Mallory kit in both my 1973 - 302 Mustang and my 1971 F100 - 351W. After running them for about a week the 351W started to run rough, I opened the distributor cap and found the contact on the end of the rotor was bent and the platic was melted. The distributor cap is a Standard brand blue that appears thicker than stock. I had to put the points back in.
Now the Mustang is running rough. Everything looks good with the Mallory kit but it acts like an ignition problem.
Any body else have similar experiance with the Mallory conversion?
Remember, if you can\'t be good, be good at it!
mdsporrer is offline   Reply With Quote
03-16-2008, 05:33 AM   #2 (permalink)
PaulS1950
Re: Mallory Ignition E-Spark Conversion Kit
Without knowing which Mallory kit you installed it is difficult to help or comment.
Paul
Mallory Hyfire vs MSD ignition boxes frdnut All Ford Techboard 7 08-03-2007 08:33 PM
Mallory Ignition Elbeam2000 All Ford Techboard 1 04-30-2007 03:42 PM
MSD distributor & Mallory ignition PhiberOptik All Ford Techboard 2 07-16-2006 09:19 AM
Mallory VIIC CD ignition Pro kleetuz All Ford Techboard 3 03-27-2006 06:00 AM
Mallory hyfire 6 cd ignition box Cman All Ford Techboard 4 03-17-2003 04:27 PM
Holley
