03-22-2008, 03:14 PM   #1 (permalink)
mdula
9" axles are stuck. Cant remove them
Guys, I aquired a 9" rear end and I started to dissasemble it. With the 4 retaining bolts removed and brakes removed, I can NOT get the axle to budge. I let the axle bearing soak in WD40. We tried hitting it hard with a hammer, heating the bearing with a torch and lifting the entire assembly up in the air by the axle flange!
Still does not budge, didnt even slightly move. The axle is a '69 model and has never been torn apart. Everything moves and rotates freely. What am I missing?? We have beat the crap out of the axle flange trying to get it free from the housing.
Any tricks or ideas???
'69 Ford Torino Formal Roof 302
Live for this!
mdula is offline   Reply With Quote
03-22-2008, 03:30 PM   #2 (permalink)
2800R
Re: 9" axles are stuck. Cant remove them
Slide hammer works great.
2800R is offline   Reply With Quote
03-22-2008, 03:53 PM   #3 (permalink)
valleydude
Use one of the drums reversed on the axle with a few lug nuts loosely tightened and use that like a slide hammer , worked when I pulled mine apart.
valleydude is offline   Reply With Quote
03-22-2008, 03:54 PM   #4 (permalink)
mrboomy
Most old motor heads that I know suggest that you attach the wheel to it with the lugs on maybe a few turns, and use the tire as a slide hammer. Push the tire up on the studs as far as they will go, then pull back as hard and fast as you can muster. I've heard of it working when a lot of other things would not.
2002 Volkswagen Jetta GLI 24V VR6 6 speed
1998 Ford Taurus LX 3.0 Vulcan OHV
mrboomy is offline   Reply With Quote
03-22-2008, 04:30 PM   #5 (permalink)
mdula
Ok, I can give that a shot. I figured lifting the axle on end and pulling up on the axle using the weight of the rear end to oull out the axle would work. Now Im just sore.
Problem is also that the alxe is not bolted to a car, so using a slide on it just want to move the entire housing with. Jeeeese, didnt think this would be difficult.
Live for this!
03-22-2008, 04:51 PM   #6 (permalink)
mustang42782
And now after hammering on the flanges you will need new axles as well.
03-22-2008, 06:08 PM   #7 (permalink)
mdula
Im aware of that. These axles are rusted, and one has a broken stud. They will be replaced.
Live for this!
03-22-2008, 07:58 PM   #8 (permalink)
torinojimmy
all i can say is try to brace it reaaly well and use a slide hammer
4.10's are highway gears
torinojimmy is offline   Reply With Quote
03-23-2008, 09:32 AM   #9 (permalink)
MCCUTCHEON4
The reversed drum trick worked for me too. I also built a slide hammer out of an old axle. I drilled the holes to 5/8s then slipped a piece of schedule 40 pipe around the axle and welded a stop on the end. It worked well.
MCCUTCHEON4 is offline   Reply With Quote
03-23-2008, 10:05 AM   #10 (permalink)
maverick5oh
this is the way I did a 8 incher that did not want to cooperatate !!!! Brace one end with a chain to a solid structure(cement colum...) with another chain, bolt it down to the axel flange using two of the studs across from each other and making a "U" with the chain and use a pulling device !!!! (truck<car<come-along<horse<cow<dog....) or a 31 spline axel shaft "T"ed on the chain and bang it out !!!!good luck !!!!
maverick5oh is offline   Reply With Quote
9" Housing and 2 pairs of axles strtcar Parts for Sale 11 09-26-2007 02:14 PM
need help for 9"rear axles olds55 All Ford Techboard 1 08-05-2007 10:43 PM
WTB 31 spline 5 lug axles for 69/70 'stang 9" 70sportback Wanted 0 06-24-2007 07:08 AM
Key stuck in ignition, cant remove!? Cyclone Joe The Garage 16 08-03-2005 07:49 PM
my rear. got axles out, now carrier stuck? 67ragtop All Ford Techboard 12 06-07-2003 12:14 AM
