04-01-2008, 06:49 PM   #1 (permalink)
hotrodconsolo
cam advice please
hi all, i need some help picking a new solid roller cam for the 408. my comp street roller, 254-260 @ .050 .621-.627lift. shed itself of its gear teeth. im going to a stock pump and drilling the hole in the galley plug to help it from happening again. anyway, is there a different cam out there that is more forgiving on the valve train as far as longevity for the lifters, springs etc. if i dropped like 6 or 8 degrees duration and a little lift would i lose noticable power under 6000 rpm? how about a custom grind? any custom cam makers i should talk to? or i could just put the same stick back in it.
thank you all
hotrodconsolo is offline   Reply With Quote
Need advice ksilvy C4 Transmissions 6 08-27-2007 05:45 AM
Need advice on 2V heads. Also cam advice. Rancho Lenny All Ford Techboard 3 10-22-2004 09:51 AM
help /advice giddyup1 All Ford Techboard 3 07-28-2004 08:39 AM
My first 460 Advice please ScreaminC All Ford Techboard 1 04-29-2003 12:36 PM
need advice strokerman All Ford Techboard 3 04-20-2003 07:31 PM
