04-05-2008, 08:47 AM   #1 (permalink)
elsanyo
gear change up or down
hey guys and girls , I've got a low gear set installed in my c6 and wanted to know if I should change my rear gears back to 3:73 or higher .I am now running a 9"with 4:11 and a Detroit locker
elsanyo is offline   Reply With Quote
04-05-2008, 09:26 AM   #2 (permalink)
n2omike
Re: gear change up or down
It depends upon what you want to do with it. If the 4.11's get on your nerves on the street, change to something taller. If you want to maximize performance at the track, stick with the 4.11's.
Good Luck!
66 Mustang, Toploader 4-speed
Pump Gas 306, 10.157@133.68
04-05-2008, 06:21 PM   #3 (permalink)
Spali32
3.55's are the middle of the road. You get both mileage and performance. You must be turning some really high rpms doing 60mph or 70mph with those 4.11's. An overdrive would be the ticket and then you could still retain the 4.11's. Life would be GOOD!!
www.spalisautodetailing.com
347 Stroker/XE284H(284/296 dur, 240/246 dur @ .050), BG 650 VS Speed Demon, Ported Victor Jr intake, Jack Roush World Jr Heads (ported from 180cc to 195cc)(upgraded to 2.02/1.60 valves) 260cfm/190cfm @ .550 lift, 11:1 comp..400hp(280-290rwhp)
Can u change 5th gear? Fordota All Ford Techboard 7 05-08-2007 08:03 AM
Gear change SweetStang All Ford Techboard 2 04-11-2007 09:55 AM
How do I change dizzy gear??? strtcar All Ford Techboard 4 02-25-2007 11:54 AM
gear ratio change elsanyo All Ford Techboard 5 02-26-2005 10:34 PM
Distributor gear change? mikes82GT All Ford Techboard 11 04-16-2003 10:05 PM
