04-08-2008, 09:58 AM
dfree383
Re: AFR 185 issues
I've never experianced it, but several machine shops I deal with have seen / Told me similar guide and wear issues with SBF AFR and SBF TFS's heads over the years.
Soft Guides? To good of Oil Control? Improper Tolerances when Built?
Unless your valve train geometry is way off, i'd look towated some harder guides and maybe a little "Softer" oil control to allow them to get a litte more oil.
Is yours giving you any indications of a problem? Oil Consumption? Valve train noise?
04-08-2008, 11:53 AM
95sporty150
Re: AFR 185 issues
im going to finish my teardown tonight, it hasn't given me any indication, so far. Most guys who have the above issues have a couple of thousand miles on them. I would rather play it safe though now, instead of dropping a valve later.
04-08-2008, 03:10 PM
bmcd66250
Re: AFR 185 issues
I had a set of AFR 185s that had three valve guides worn out after about 2000 miles. One was so bad that the the valve could be moved sideways about 1/16".
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, Holley 650 DP, long headers), "Z" T5 w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
04-09-2008, 03:02 AM
Mikes66
Re: AFR 185 issues
Wow, it would be interesting to know if there is a pattern to which valves guides are going bad. Like ones on the passenger side, vs, the drivers side, ones in the front of the motor vs the rear of the motor.
My thinking is, maybe unbalanced water flow,(some valves are running hotter then others...) or oil pressure is lower in some locations, meaning the oil does not lube the rockers equally in different parts of the motor, from a weak oil pump...
[SIGPIC][/SIGPIC]
04-09-2008, 04:52 PM
1 Bad 88 GT
Re: AFR 185 issues
Piss poor valve guides. Plain and simple.
04-09-2008, 06:36 PM
iwantmore
Re: AFR 185 issues
I would wonder if any one had this problem with pedestal rockers since they will center. I have noticed the guide plates leave a lot of room for error and could take out a guide. I also needed to get 0.0150 longer push rods to get it right. Just a couple things that could cause wear.
04-10-2008, 03:02 AM
dennis111
Re: AFR 185 issues
All great points. Improper valve train geometry can be hell on even the best parts. How many people buy heads and just "slap em on" without checking alignment and clearances? (This statement is not directly pointed at the OP, but he might want to recheck valve/spring/pushrod/guideplate alignment during reassembly.)
Each engine combination will have its own needs. I found that a set of Manley SBF guide plates does a better job of alignment than the original AFR stuff when using 1.7 ratio rockers. I also needed 8.250" pushrods, as the stock length would have been way short on my 205's.
Dennis
11.52@121.29mph
04-10-2008, 08:24 AM
#9 (permalink)
bmcd66250
Re: AFR 185 issues
Mine were with FMS pedestal roller rockers.
04-10-2008, 08:35 AM
#10 (permalink)
jrosengarth
Re: AFR 185 issues
I started using the ISKY cams adjustable guideplates. They are made for Chevy's and need some clearancing work to make them run on a Windsor small block, but you can get the rocker aligned dead on with the valve. Best $50 I spent on the top-end IMO.
-J
