05-09-2008, 03:02 AM   #21 (permalink)
cmf60
Re: 351c street sometimes strip
Its .515" / .541"
IF YOUR USING OTHER PEOPLES IDEAS YOU ARE ALWAYS GOING TO RUN 2nd.......
05-09-2008, 03:23 AM   #22 (permalink)
Spali32
Yeah, sounds like he's set with using a cam around the .524 lift area. That .541 lift might be a little too high for him and the springs he wants to reuse.
www.spalisautodetailing.com
05-09-2008, 04:19 AM   #23 (permalink)
cmf60
He is considering a cam with .526" / .536" ....
Good luck with it anyway.
05-09-2008, 10:44 AM   #24 (permalink)
machwone
is .524 to .541 too much for the srpings? since i have no clue what the spring pressure is or what they will take i want it to be a s close as possible to what is in there now (.524) I thank all of you for the advive you have given me. I agree that a different cam would be better like the XE would be a great cam or the 275DEH. I think that the .536 lift is max for me like I always say better safe then sorry
machwone is offline   Reply With Quote
05-09-2008, 07:26 PM   #25 (permalink)
machwone
any suggestions?
05-09-2008, 07:56 PM   #26 (permalink)
cmf60
Yes..... are the springs you have new? If they are old/oem...toss em. If new(ish) I would find out what (rate) they are. Take one off and get it tested, if you can't find what they are. See if they are close to what the cams needs are....no-matter which cam you choose. Make sure they are at/near correct installed height.
Springs are a critical part of the deal....whatever the cam. Weak or mismatched springs are a recipe for disaster. Clevelands with OEM valves are re-knowned for losing the odd head/pulling keepers thru retainers = hurt/destroyed engine. Not enough spring pressure is worse than too much... it promotes dropping valves.
Suitable springs and decent valve/valve gear are the best insurance you will buy for a Cleveland.... period.
05-09-2008, 08:18 PM   #27 (permalink)
machwone
springs are newish 5k on them. I assume that the machine shop ( a good one) matched the cam and springs but i dont know. I called them but its been too long and he doesnt remember, i told him what cam i was thinking about gitting (crane h-288-2) he said it would be fine. The reason im saying the crane insted of the comp (280 h)is that the crane has different lifts and durations toward the exhaust also the power band is higher which will match my torker intake
what do ya think?
05-10-2008, 04:05 AM   #28 (permalink)
Spali32
I think your going to sleep a whole lot better getting NEW springs and knowing for sure how big a cam you could install. 5 year old springs......it's a gamble I wouldn't want to take. New springs are not that expensive.
05-11-2008, 12:34 PM   #29 (permalink)
machwone
ok I went to the bank today and and got my $1200 from the goverment. So I'm going to put the xe-284 cam and spring kit along with m torker and the headers what hp so it make?
also if i understand this right my 3inch is over the top but it doesnt hurt anything compard to the 2.5 inch right?
05-11-2008, 03:20 PM   #30 (permalink)
plovett
Yeah, 3 inch pipes will not hurt anything. Needing back pressure in the exhaust system is an old wives tale IMO. People have heard it repeated (mostly by car mag's) so often it became a fact.
By the way, Edelbrock does not make an RPM or Airgap intake for the 4 barrel 351C heads, so it's a good thing you decided not to buy one. Blue Thunder makes a good dual plane intake for 4 bbl heads. It's pretty pricey, though. Something like $425.
paulie
1967 Cougar. 517 hp. 432 cid FE. C6, 9 inch rear.
plovett is offline   Reply With Quote
408 Windsor street strip Bluemach170 All Ford Techboard 13 10-05-2007 07:23 PM
b&m street strip trans jetnoise All Ford Techboard 1 03-17-2007 10:36 PM
Milodon Street/Strip Pan? growlin351w All Ford Techboard 2 07-09-2003 02:49 PM
street/strip gears for 9" slick mo fo All Ford Techboard 8 03-17-2002 09:29 PM
want to build a killer street/strip 351c gtnrb71 All Ford Techboard 13 02-17-2002 03:10 AM
Holley
