05-11-2008, 03:51 PM   #31 (permalink)
cmf60
Re: 351c street sometimes strip
The Airgap will work with either 2V or 4V heads. I have not personally tried one yet but from what I have come accross, the results have been very good with both types of heads.
IF YOUR USING OTHER PEOPLES IDEAS YOU ARE ALWAYS GOING TO RUN 2nd.......
05-11-2008, 04:11 PM   #32 (permalink)
plovett
Sounds like a really bad idea. You have fun with that. LOL! Seriously, I'll withhold final judgement until I see somebody actually try it. The thing is, the 2 bbl port is not only smaller, it's in a different location.
paulie
1967 Cougar. 517 hp. 432 cid FE. C6, 9 inch rear.
plovett is offline   Reply With Quote
05-11-2008, 04:14 PM   #33 (permalink)
machwone
well then the torker will be fine, i didnt want a dual plane intake, i have had bad luck with them plus that im running 1000 to 6500 ish so a single will work best.
any idea on hp or times it might run with a 3.80 and 4 speed
machwone is offline   Reply With Quote
05-11-2008, 05:14 PM   #34 (permalink)
cmf60
paulie
Yea, I know where you're coming from paulie... from actual results with both heads, they seem to be the goods for a street engine but will also reserve my decision till I try one myself as well. They are intended for use with both types of heads....even with the port mismatch....it ain't about size, its about velocity.
Machone, I would expect you should make around 440fwhp with stock heads and an XE284.... but you will give away alot of street manners with that cam/setup.
05-11-2008, 05:50 PM   #35 (permalink)
machwone
k, would hp change a lot if i went with a smaller more street cam like the crane h-288-2, soo many people telling me what to run i went with the biggest but i havent order it yet maybe around 425hp i can live with that
05-11-2008, 07:45 PM   #36 (permalink)
ckelly
The H-288 should make a little over 400 - provided you zero deck the block and everything else is spot on. A dual pattern cam is a better deal in a 4V engine because the exhaust is worse on a 4V head than a 2V. If both are ported, the 2V is typically still better. If you spin an H-288 to 6500 you're just showing off, the cam will like to be shifted at 5800~6000.
If you want to run a dual plane on a 4V, run an Ed 4V dual plane because it puts the exit to the manifold port in the high activity portion of the 4V port. The new Air Gap does not - can't because the ports won't line up with a 2V port. Just sticking the higher velocity flow into the 4V port will help some, but it's far from optimal.
As far as ET - don't think you said what kind of car this is going in.
Ed Air Gaps make big power into the 6500 range. carjunkietv.com just did a dyno test with a dual plane vs a Victor single and the dual held it's own against the signal and typically made more torque in the range you specified.
A 650DP will probably run better on the engine also.
05-11-2008, 11:15 PM   #37 (permalink)
machwone
The motor is going into a 67 mustang coupe. I have a torker and money is tight. I got the comp cams dyno and it said around 420hp do ya think a duel plane would be that much better
05-12-2008, 01:02 AM   #38 (permalink)
Spali32
A dual plane will be great for the mileage/street driven. A single plane will be better for all out performance.
[URL="http://www.spalisautodetailing.com"][SIGPIC][/SIGPIC]www.spalisautodetailing.com[/URL]
347 Stroker/XE284H(284/296 dur, 240/246 dur @ .050), BG 650 VS Speed Demon, Ported Victor Jr intake, Jack Roush World Jr Heads (ported from 180cc to [B]195cc[/B])(upgraded to 2.02/1.60 valves) 260cfm/190cfm @ .550 lift, 11:1 comp... 450-475HP
05-15-2008, 02:48 PM   #39 (permalink)
machwone
I think i will stick to the torker since i have one. i want to install 3.80 gears but maybe a 4.11 will be ok. i want to be able to use my powerband while on the freeway with the wimpy 272h cam what gears should i run?
408 Windsor street strip Bluemach170 All Ford Techboard 13 10-05-2007 07:23 PM
b&m street strip trans jetnoise All Ford Techboard 1 03-17-2007 10:36 PM
Milodon Street/Strip Pan? growlin351w All Ford Techboard 2 07-09-2003 02:49 PM
street/strip gears for 9" slick mo fo All Ford Techboard 8 03-17-2002 09:29 PM
want to build a killer street/strip 351c gtnrb71 All Ford Techboard 13 02-17-2002 03:10 AM
