05-06-2008, 09:43 AM   #1 (permalink)
69thunderbird
429 Hesitation - too Lean or Too Rich?
I have a 429 with a holley 770 street avenger - when i step into it backfires and hesitates - is this because i'm starving the carb or dumping too much fuel?
69thunderbird is offline   Reply With Quote
05-06-2008, 09:46 AM   #2 (permalink)
PaceFever79
Re: 429 Hesitation - too Lean or Too Rich?
Sounds like you may have the timing off. Check the initial timing, and the vacuum advance, also look for a worn distributor cap, rotor, old or arching plug wires, before looking at the carb.
PaceFever79 is offline   Reply With Quote
05-06-2008, 11:42 AM   #3 (permalink)
My427stang
Almost certainly not rich, although in extreme cases it could blubber or foul plugs and then cause a backfire
I would first check to see if the accelerator pump works with even the slightest throttle movement with no bubbles or spits. If it isnt nice clear immediate streams, fix the accel pump
Next would be checking the firing order, then check for vacuum leaks
Last would be a leakdown test looking for a bad intake valve.
70 Sportsroof, 427 FE/489 cid, 10.7:1,Ported Edelbrock heads, and RPM intake, 1000 Holley HP, Ceramic Hooker Supercomps, TKO-600, 3.70, A/C
My427stang is online now   Reply With Quote
05-06-2008, 12:04 PM   #4 (permalink)
Mikes66
Yes, check the adjustment on the accelerator pump. It should give a good squirt when you move the throttle a little bit more then a tap.
[SIGPIC][/SIGPIC]
lean or rich Tracer64 All Ford Techboard 10 04-26-2007 10:25 PM
anybody using a MSD rich/lean indicator?, O2 Sensor Dogface All Ford Techboard 13 06-04-2004 12:07 AM
symptoms of a carb running to rich or lean? tbirder All Ford Techboard 2 07-18-2003 01:05 PM
Carter 625 cfm....too rich or too lean? Kevin69mach All Ford Techboard 3 07-10-2003 11:09 PM
MSD rich/lean indicator stocer All Ford Techboard 18 01-04-2003 02:56 PM
